My 1984 GL 1200 while on a long run the engine started to cut out sputtering; I also notice my rear brake light had come on steady, the gear selector flashed on/off intermittently I pulled over and turn key to off position. Turn key on and no lights nothing. How ever I was able to pop start and drive home. Thank God I had my Honda Goldwing lol:raspberry:
Now to find the fix any ideas what when wrong?
possible Ignition switch shorting,they do have the park position that turns on the brake light or tail light.will it run now?,if so wiggle the key around and see if it makes any change.
Honda Guru
There is a FACTORY recall concerning the ignition switch on the 84 GL1200's. You might take the VIN number to a dealer to see if they can look up the information if the recall has already been performed.
If you need I have info. PM me if you need it.
