That's bad news. The oil pump is driven by a chain in the rear case, never heard of one breaking but it could happen. It's an engine out job either way and engine disassembly to get to the main pump.
I appreciate your feedback but the engine is not making any knocking noise and there’s no metal particles in the oil that was drained…Sounds like lifters are clacking a bit but not severely.From what you list i would expect crank/bearing damaged, cheapest option is a used engine im afraid, rebuild cost are high
Well, if you knew the oil passages well enough, you might be able to do something like remove the oil filter and snake a camera through the main feed from the oil pump and be able to see if the rotor is turning when you rotate the engine. I can think of some engines where this would be possible but many that wouldn't. No idea about the 1500 as I've never had one that far apart.
I almost forgot, you can remove the water pump and see if the oil pump shaft is even turning. No turning would confirm a failure, but the pump rotor could have sheared the drive key so a turning shaft won't confirm function.
Thank you again!Well, if you knew the oil passages well enough, you might be able to do something like remove the oil filter and snake a camera through the main feed from the oil pump and be able to see if the rotor is turning when you rotate the engine. I can think of some engines where this would be possible but many that wouldn't. No idea about the 1500 as I've never had one that far apart.
Ok I’m following along with you in my service manual.Factory service manual to the rescue. Yes, you can pull that cover Without pulling the motor.
woudnt the bike have been running hot as you lost oil pressure?Ok I’m following along with you in my service manual.
I’m with you as far as:
Remove water pump validate if the oil pump is driving the water pump shaft.
man’s I understand the process to remove the front cover but I’m not sure what the purpose for this procedure is about.
(Sorry if I misunderstood)Thanks again.
Terry
It would take a while for it to start getting hot. He probably wouldn't have noticed in 1/2 mile.woudnt the bike have been running hot as you lost oil pressure?
Got it. I will dig into it and get back to you with what I find and we’ll go from there.How far you have to go in depends on what you find along the way. Just removing the water pump hose then seeing if the impeller turns when you turn over the motor will tell you something. If it isn't turning, the engine has to come out.
If it is turning, you can pull the front cover and look into the oil pump to see if the rotor is turning with the shaft. If it isn't there is a problem with the rotor spinning on the shaft. Engine has to come out. If it is turning, you have to look at other reasons you have no oil pressure. Oil transfer tube broken, oil pickup broken off, oil pump casting broken, etc. All things you will see once you get the front cover off. More than likely the engine will have to come out no matter what you find. But you will be in a better position to decide if you want to repair your engine or just get a used engine. Some new parts are not available so used may be your only option anyway.
Thank you for your feedback.It only takes seconds of no oil to score a bearing shell and journal, personaly i would not trust that engine
