I was workin on wing today, runs great. still have problem no power fuse #3. on page 25 ('85 etm) shows powerinto and out oftaillight relay and connector-c92 4-blk which i can't find. can you give me any ideas? i'm looking by radiator cap rite side of fork. i did find a blk rectangle thingy could be a relay but has red-4 connector on it, and wires are small and no wht. ithas E65 on it.am i lookin in right area? i checked c1-blk21 connector and the blk wire-no power that goes to fuse #3. do you have any ideas where to find the taillight relay? could it be in ritestorage pocket?
rob
Edit corrected that you checked that last time...
The tail light relay should be under the ignition coils on the right side.
thanks sam and dave, found it. it was where it was supposed to be...of course. pulled cover off and pushed relay coil and powered the fuse #3. now where to buy replacement? mother honda doesn't list "taillight relay" as is in manual.
dealer called a "main relay" #38501-GN2-003,$37. i ran that number ebay found 1 for $15 and called it "starter relay".
any ideas?
That's a little high IMHO for a used relay. Just about any 4 pin relay could be wired to work in that circuit.
That 38501-GN2-003 seems to be the correct relay, Honda parts are confusing sometimes on the nomenclature. You have to know what you are looking at to find a part a lot of the time.
any ideas?
Rob, before replacing it are you getting 12v to black wire with key on.
At the 4 wire connector with relay removed:
-white should have 12v at all times (battery connected)
-one black wire should get 12v with key on
-other black wire nothing
-green wire continuous to ground
Discussion Starter #10
thanks, actually i can't get to connector. it's under coil. i can see rubber boot and removed to see top of relay. pulled top off to expose the relay coil and points. moved points and the power to #3 came on. i can wiggle points and on/off/on power. the connector i can't see but i figure there must be a lock. so tomorrow i'll feel for it and get off. that should make easier to replace.
