On my Gl1100 Aspencade...
The CB/Radio/Cass was working great,I have no sound now,all the units power up & everything works on the dash & also on the handlebar controls,I decided to change my screen,I had difficulty getting the 2 bolts loose from the chrome piece,they just kept turning,I got the rubber mat out & i used a hacksaw to cut bolt between old screen & back of that chrome piece that holds the screen,to get to the other end of bolt after cutting,I loosened the dash from inside the turn signals & loosened speakers & then pulled bolt out & I put that odd shape nut back in its socket,after refitting the screen,there is no sound from all the clarion units,have I moved something,the only wiring I touched was inside the turn signals,I did notice a white wire in the left & right turn signals & they were not connected to anything,at the end of the white wire is a rubber sleeve,I moved fuse holders around on the left side,so I could get my hand in.Would that white wire come from the amplifyer.
Speakers are working,I can hear the squelching as I turn the cb on.
Any help would be much appreciated......Thanks
