Yes I checked all fuses, The tilt sensor checked good. Kick stand switch, ok . Turns over good but no spark to plugs. Bike has only 4950 miles on it.I immediately suspected the crank position sensor but I suppose that is what you called the PG you replaced. Have you checked the fuses? I can't get my 01-05 ETM to open so I can't say which one exactly.
As I said, it won't even crank with the kill switch off so no worry there. I guess you are going to have to do some diagnostic work at the ECM connector. Do you have a manual?Changed the fuse with a new . Old fuse good. changed the relay. The motor cranks over good but no spark. Kill switch is good. Works ok.
I have a 2003 goldwing and took ECM out of it and put it in the bike still no spark.As I said, it won't even crank with the kill switch off so no worry there. I guess you are going to have to do some diagnostic work at the ECM connector. Do you have a manual?
The bank angle sensor has been checked ok and tried a different on in place of it still no spark.I wonder if the bank angle sensor got twoinked in the accident?
Yes, twoinked is an engineering term.
An 18 year old motorcycle in a garage and it only has 4950 miles on it. There is always a posaibility that rodent activity has happened. If so, it will not be seen readily. A deeper inspection will certainly be needed.Yes I checked all fuses, The tilt sensor checked good. Kick stand switch, ok . Turns over good but no spark to plugs. Bike has only 4950 miles on it.
If it was in a garage, there is especially a chance that mice got into it. Mice hate being outside in the winter, so,...
Ok thanks I will check it again.If it was in a garage, there is especially a chance that mice got into it. Mice hate being outside in the winter, so,...
