1 - 2 of 2 Posts
'85 GL1200
I got my GL1200 back together after doing the stator and head gasket. I had it running, and it just died. Now I have no spark. It turns over fine. I checked spark at the plug wires. No spark on any of them. I am thinking that when I put the timing belts back on, I may have forgot to check the pulse generators. I think I just tightened them a bit, planning to come back to them. Is it possible that those shifted so that they are not making spark? I forget if they are adjustable in there, or if you just crank down the bolts that hold them. I’m wondering if they worked loose and I need to pull it apart again.
Any thoughts on that?
There is no adjustment. Check the connector where the PGs plug into the spark unit.
1 - 2 of 2 Posts
