Hello all,
Working on a 98 goldwing 1500 trike. Just swapped motor.
Everything hooked as it should be. I am not getting spark when turning over. I've read some other threads to eliminate any possible relay, fuse, kill switch. There is cruise control vacuum, but has no buttons for cruise. All starter relays check out good. Battery at 12.68. Draws to 10.9- 11.2 when cranking. Reverse light illums when reverse engaged and won't crank as it should. All fuses are good. Only bad thing I've found is that the clutch switch is bad. I bypassed that with a jumper. I can't find any side stand switch anywhere. I have checked all 6 plugs for spark.
I am mechanically inclined. Just never worked on a lot of jap stuff. My clymer book isnt really telling me any troubleshooting th as t I haven't tried. Any help is appreciated. Thanks in advance
Mouse
Mouse
