21 - 40 of 67 Posts
Redwing will be along and maybe dave,they can get the issue figured out.
Are you sure you got the pulse generator plugged in? Wire comes from under the timing covers.
  • Like
Reactions: redwing52
You have one strange bike but regardless it will not run without a pulses from the pulse generators. Verify that first.
I knew the Gurus would be right along👍👍👍👍
Based on what I see in the post # 7....
It started life as a 1991 - 1994 Interstate. There are several "tell tale" items I see.
Since it has the "white gauges" and he says it is a 1998, I will assume it possibly has a 1998 Aspencade or SE engine. Possibly the SE since it has the SE emblem.
Some questions:
How much was changed (electrically) during the engine swap....?? Was the ECM changed....?? How much of the starting/ignition circuit was changed...??i
Definitely the instrument cluster has been changed to a 1998 or 1999.
He says it is cranking. A 1991 - 1994 will crank with the Kill switch OFF. A 1997 and later will not crank with the Kill switch OFF.
So we don't know if the Kill switch is good or bad....!! Or if the ignition relay is good or bad...!!
Difficult to troubleshoot this without more information.....!!!
The radio cover is suspect of not being Aspencade?but that won’t keep it from running.
Where do you see the SE Emblem ?
02 GL1800 w/Auto Pilot
since it started out life as an SE, wonder who stole the right grip controls?
I was in the Navy in the early 70s with a MW that just went by Mouse.
gumbyred
Probably didn’t want to spend the money for the SE one,that one is cheap.
Well, since the bike started at as a SE, the proper Cruise Control buttons should have already been on the bike.... so why take it off, and install one from an Interstate?
Something wrong with the switches, damage, or other reason.
Did you read post # 27 where I asked if the VIN number plate had been swapped over from the bike the engine came from....????
If so, then the frame/body and engine are two different years......!!!!
The picture he posted in post # 7 would indicate it is a 1993 or 1994 year bike (if that is the original color).
If that is the bike he is working on......!!!!!
No,
I missed that post, and thus the loss of the hand grip control.
21 - 40 of 67 Posts
