I guess you're not working on what I thought, never mind,
I truly need everybody's opinion here. Your thought might be the solution to my bike's problem. I have already spent a lot of money to make this bike work. I'm desperate.I guess you're not working on what I thought, never mind,
My bike has only one horn. I bought it that way. The horn now works after I've found a break on white green wire. The main ground is clean. The other ground at the left near the steering post is clean as well. I think it's called ground 102 by the manual. I'll verify if the fuel pump is pumping gas when I gets home.On my '86 Aspencade the digital tach will try to show an rpm when trying to start, analog you may not see that. I'm wondering if the problem is with the bikes 'ground' system. The signal you're looking for is a ground on the control wires (yellow / blue). That signal has to go to 'ground' for the coil to "fire". The RPM signal is on one of the coils and the 'on/off' function creates a pulse that the digital tach translates to rpm. The other coil signal (on/off) turns on the fuel pump relay. You could test that relay to see if it's turning 'on', which you need fuel to run, could remove the pump discharge hose and verify that function.
May need to verify that the "grounds" are good, easiest done by following the factory Electrical Troubleshooting Manual.
I'm not sure but it seems like I remember someone finding corrosion between the coil and bike frame mounting point, but that may have been a different model of Wing.
Corrosion of 'ground' connections will make 'grounds' not function as designed.
Do both of your horns work?
I have no pulse on the yel/blu wire. The blu/yel wire does not pulse either to send on/off signal to the fuel pump hence the fuel pump is dead. I have a good ground on the fuel pump.On my '86 Aspencade the digital tach will try to show an rpm when trying to start, analog you may not see that. I'm wondering if the problem is with the bikes 'ground' system. The signal you're looking for is a ground on the control wires (yellow / blue). That signal has to go to 'ground' for the coil to "fire". The RPM signal is on one of the coils and the 'on/off' function creates a pulse that the digital tach translates to rpm. The other coil signal (on/off) turns on the fuel pump relay. You could test that relay to see if it's turning 'on', which you need fuel to run, could remove the pump discharge hose and verify that function.
It may be the kill switch, work it off & on and see if the voltage changes. What I would do is install a relay.I measured voltage on blk/w wire from connector 78 (red connector on right side of ICU) and connector 121 ( white connector on left of ICU). The voltage reads 7.41 volts. Since it's the same blk/w wire, there should be no voltage drop here ideally. So this could be the problem, a bad blk/w wire causing big voltage drop. I'm I right? Now, what shall I do to circumvent this bad wire?
That's not enough, it probably needs 10.5 volts to fire. 12.58 volts is a battery in need of charging.The cranking voltage when measured was 8.57 volts.
Yes, a test light will pulse, it a direct ground signal. You do have to connect the test lead to positive. What's a bigital meter?If you were trying to get a test light to pulse on the pulse coils it wont work as they only give millivolts, a bigital meter might show a varying voltage
I misread what you wrote before. You are correct but in this case I think the pulse rotor is not turning so there won't be any voltage reading but he was testing the wires between the ignition unit and the coils where there should be a pulse readable with a test light.Digital multi meter, i found an analogue meter needle did not move but a dmm showed varying numbers on mV scale. I am talking about measuring across the pulse coil leads when disconected, every time the trigger wheel passes a coil a small voltage is generated , read by ecu and fires coil
I guess it took them a while to realize they didn't need the part adapted from the 1100 on the back of the engine when it would be simpler to put them at the front.I misread too, i took the colours quoted as the pulse coils not the ht coils, we all get there eventually.
Long distance electrical diagnosis is always a bugger!
I wonder why Honda changed the position of the pulsers during the 1200 run.
