mmonsterbuck
well boys, battery was low but turned over, then it stopped, so i put bat. charger on, now their is nothing. no lights, no gauges lit. checked 30 amp near bat., its ok. tried to put charger on bat., went to default. checked the dog bone fuse behind tank, its ok, but i pulled the relay next to it, then the charger worked. so somethings wrong their with relay maybe ?
Do you have access to a volt meter?, check the battery, should read 12v or more with the key off. check the fuses.
mmonsterbuck
newie, tried that,ok,checked fuse block by back fender, bone fuse ok, checked relay next to it, unpluged it and bike had power, pluged it back in and it started. ive started it 5 times now and it starts right up
