1 - 3 of 3 Posts
Deceased 1/2017
Just rode in this morning and had turn signals and had to move for a big rig to unload and now have no turn signals. I checked the fuses and they are good. I have hazard lights but no turn signals. What would make them go out that quick? Any ideas??
The 1200 guys will be along. I think there is a diode in the turn indicator circuit to keep it from interfering with the hazard flasher. So you may have a bad ground in the back of the bike (maybe a connector came apart), bad diode(low probablility), or you need a new flasher unit.
Turn flasher. Happened on my 83 aspy, they would work intermitintly, replaced flasher and they worked fine. Get a flasher for LEDs, then at some point you can put LEDs in if you want and the will flash rate properly.
1 - 3 of 3 Posts
