I just installed a new compufire in my '08 1800 and it is very loud. It is making a whirring sound similar to what you might expect from an alternator that is working hard. It is also making a gear noise, similar to what you might hear when the gears do not have enough clearance. It is audible with the side cover on as well. During the install, I had to use the three mounting bolts to draw the alt into position. I could not even get the unit's O ring up to the engine case. I tightened the bolts as uniformly as possible. I called compufire and asked if the noise was to be expected from their unit and he said, "I don't know".
He suggested returning it to be checked out. After his response and reading about others' experiences with their customer service, I hesitate to do that. According to my aftermarket volt meter the unit is producing acceptable voltage.
I have read several reports of compufires being louder on 1500s but I haven't read anything about the gear noise. I am wondering if anyone has installed a compufire on an 1800 and experienced similar noises and, if so, how long did the unit last? Thanks.
