I just replaced all the lights on the back of my 2015 Motor Trike Razor conversion with LED lights. Now the radio is noisy only when the brakes and/or turn signals are applied. I know it's caused by the new lights but what do I need to do to correct the problem? Alternator noise filter? Ground loop isolator? Any help with this problem would be greatly appreciated! Thanks, Diane
Hallo Diane
And good luck with your Wing.
1998 GL1500 Asp and 2017 GL1800 4AC
The LED's generate a radio frequency and interfere with the reception. There is no easy way to mitigate that. The conventional fix would be to put a ferrite bead or choke on each power wire near the individual LED bulb.
This is from Wikipedia:
"A ferrite bead or ferrite choke is a passive electric component that suppresses high-frequency noise in electronic circuits. It is a specific type of electronic choke. Ferrite beads employ high-frequency current dissipation in a ferrite ceramic to build high-frequency noise suppression devices. Ferrite beads may also be called blocks, cores, rings, EMI filters, or chokes "
