:shock:I searched for quite a while and read as many starting trouble post I could stand. I hope I can run this scenario by you. I just picked this bike up, and tried a few things to get the starter to turn the motor over. It starts to turn the motor over with a surge, but then stops.With the plugs out it turn about 600rpm. I tried all kinds of batteries in full charge. Old starter was bench tested o.k. but still replaced with New (not rebuilt). I am getting miniscule voltage drop through the relay at 12.5v 700cca (-.5 v) even tried jumping the starter directly to battery terminals (thus eliminating the relay all together). I replaced the oil w/ thinner 5w30 in hopes it was too thick or cold. I cleaned grounds, checked cables, bypassed the "dogbone" fuse link etc. Engine turns free and fast when the plugs are removed, in fact it is anytime i have more than 2 plugs in when it stops. Compression too high? (It will blow my hat off looking down at it) Thoughts about hydraulic lock? any ideas? Thank you for your time and great Forum!
