Hi everyone. well after about a month of blood, sweat and tears, and practically LIVING in the garage I finally got the 84 interstate with 20,000 actual miles that had been sitting for several years to actually go down the road. when i got the wing from the P.O the back tire was bald with the cords showing and the front tire had VERY little discernable tread and was so badly cupped it looked like a giant circular saw blade. the front shocks had fifteen psi in them and the back had none. I drained the fork oil and filled with spectro 10 w. fork oil. reduced the psi to 6 lbs. in the front and put 30 lbs in the rear. I installed a new set of bridgestone spitfires and had the front tire and rim spin balanced. the rear tire was acceptable spun by hand and the high points checked aftereach spin. First ride starting at about 25 MPH and gradually getting worse till about 35- 40 MPH the bike hops/ bounces at about a frequency of two times a second. Like going over a section of washboard. I removed the front tire and had it spun again. it was right on. drained the fork oil. added kerosene pumped the shocks and drained. did this till the kerosene was crystall clear. when moving the shock sliders up and down on the fork tubes they go up and down smoothly with no binding. Pulled the anti dive units and dissasembled them. cleaned everything with kerosene. blew them out with air. coated everything with ATF. reassembled them and flushed the shocks with ATF pumping the shocks several times and draining the ATF. did this several times... Added 10.9 ounces of ATF to each fork tube and reinstalled the caps... With the handle bars straped down, grasped the forks at the bottom and tried to move them for and aft. No movement or play. tried to twist them back and forth. no play. go for a ride. same thing. bounces hops at 25 MPH worsening till about 40- 45 MPH. Not sure if it goes away after that or just becomes much less noticable. tried 40 psi front tire and 40 psi rear tire. tried 34 psi front/ forty rear. seems a little less noticble at 40 PSI front. tried anti dive units at all settings. same.... with dial indicator straight on to front tire in the middle, out of round .050"... tire side wall run out .025"... rim run out .006 "... right disc run out .009 "... left disc run out .005... Dial indicator straight on to rear tire in middle, out of round .050"... rear disc run out .005"... rear rim runout .005 "... rear tire sidewall run out, .055 Sorry for the long post but if anyone has any ideas, suggestions, or advice I would be very greatful. Hell at this point I'd even take a muffled chuckle or a stern " so ya just had ta have a wing now did ya boy?" Thanks all,Mike
