I cannot seem to turn the filter bolt without the o-ring sliding out. Does someone have a solution to this dilemma? I must have tried 15 times. Argh! good thing I had other things to do.
Yes, Vaseline and also a good grip on the filter cover to stop it spinning as you tighten the bolt.
The Irish Crew
The Vaseline or a dab of grease will fix it. Also helps stop leaks later on.
