1 - 15 of 15 Posts
Does anyone know where I can buy just the O rings for a GL1100 carbs air cut valves.
Thank you,
Mark Morell
81, 82, 2001 Goldwings
Welcome from Oklahoma :waving: Enjoy the wing :cheesygrin:
Hallo mkdm0
And good luck with your Wing.
· Banned
Ace/True Value Hardware -
They'll be neoprene-based o-rings. I've used them with good results (meaning they've held and withstood the application over time and milage). I don't remember the part number and not certain if I have any left to reference. Inexspensive.
If you want to stick to the original 'D' shaped orings (I think 1100's are), or the ACE option doesn't 'pan' out, you could try Kawasaki part #92055-1245...around $3.75 apiece.
Last week I did a carb clean on an 05 Kaw Concours (ZG1000). They're Kehein's and use 2 air cut valves on the outside carbs. I remember thinking how much the air cut orings looked like the ones on GL1100s. Unlike Honda, Kaw is really good about offering carb parts separately. The above part number is for that oring. I can't promise they're the same so maybe try one first.
Discussion Starter · #15 ·
air cut o rings
I got some from the Kawasaki dealer and they're a perfect fit, thank you. I also ordered some from cycle to cycle at .80 each.
1 - 15 of 15 Posts
