1 - 3 of 3 Posts
I was having difficulty getting the bolt started into the positive side nut inside the battery terminal and wanted to share my solution. First I tried to place a piece of small engine fuel line behind the nut as another member had suggested, but the bolt forced the fuel line out as it threaded in. I removed the fuel line. I then pushed two small O-rings into the battery terminal behind the nut to keep the nut pushed up against the front edge of the terminal. The bolt passes through the hole in the O ring and keeps the O ring in position for the next removal/install. I bought these at the local big box hardware store.
1 - 3 of 3 Posts
