I don't see how the link above "debunks" anything. Actually, if it serves any purpose, it is to show the relationship between paper filters and oiled filters with subjective hard data to compare one against another with straight-line testing, as K&N is the only oiled-element filter I see in the testing of all filters listed. Did I miss another oiled filter?
Are the common-to-another test practices used for the results even relevant for a "debunking" to even be considered?
Granted, I understand that some median plane needs to happen for any comparison to happen, but does K&N base their claims/advertising/warranty on testsdone at350 CFM flow with "test dust" particulate matter of 2.5-80 microns injected at a rate of 9.8 grams per minute? Do any of the other filter manufactures do the same?And is that comparable to 50K miles of average street driving conditions? Is it a above average accumulation of "dust" or a below average amount?
Oiled filters require maintenance above and beyond paper media filters. As I see it, looking at the results in the link above with this in mind says that the K&N filter performs exceptionally well should the maintenance required been performed when needed to maintain the across-the-board performance levels.
Without argument I think the test is biased in scope, flawedand irrelevant to all but the K&N haters.
