A friend has a 1986 Honda magna 700 and wondering what type of oil he can use other than honda oil...is it like a goldwing and can use rotella..if so what weight???
Thank for the help
All depends on if it's a wet or dry clutch. If it's a dry clutch he can you anything that floats his bike. If it's wet then no oil with "Anti-Friction" additives.
James
He definitely has a wet clutch. I'd use Rotella 15w40.
He should be able to use the same oil that is put in goldwings since it is a liquid cooled engine, it calls for 10-40 with no friction modifiers(wet clutch) if he's looking to not spend alot of $ on the hondaline brand(or other motorcycle specific brands) he could use the typical 10-40 automobile brands(NOT the energy-conserving) or the15-40 brands that many wingers use and have had good results with. He may want to use a 10-40 since the early magnas had an upper-oiling problem(low pressure) and maybe even a synthetic.
10w-40 Chevron Dello 400 is what I run in my 82 1100, will work fine for him.
does delo 400 come in a 10-40?
I'll check the jug in the am, it could've been 10w-30 I just put in.
Yep, not much difference in the basics, any oil that works in the 'Wing will be happy in the Magna.
10W40 is the recommended oil replacement for most Honda's Yamaha's, Suzi's and Kwaks.
