Delo 400 for me! works great,lot cheaper too
Not that it isn't good oil....motul is good stuff. I've ran it in the dirt bikes, though I prefer Maxima. Is it necessary??? Nope. It's a Honda. You could probably run vegetable oil in it and it wouldn't hurt it;-) You should see some of the stuff I've done to honda 4-strokes.....like dropping my XR in a river once.......and filling the engine with water. Took the tank off, stood it upside down, pulled the plug, let water pour out of the cylinder....shot some WD40 into the barrel, replaced plug....drain float bowl. Drain bottom of tank. Away you go. Crank case was so full of water....white paste was shooting out of the vent for a hundred miles. When I got it home.....when I removed the drain bolt nothing came out because the "oil" had turned into something like toothpaste. Had to pull the clutch cover off and use gumout to get it out. Then ran 5wt through it 3 or 4 times. I put thousands of miles on that bike after words.....without a hint of a problem, and last I heard it was still going strong.Yes I.m Sorry It Is But I researched Forum First!
po Said He had Been running Castrol 10w/ 30w In My Bike, went To Local & only Goldwing Shop I Know In Knoxville, Tn Today. Was talking To Shop Guru, Told him about it, He said Get It OUT!!!!! Only UseMOTUL In My 84 Aspy.
What do You all think About this oil? He claimed It would Even Make Shifting Smoother!
Thanks In Advance
(Please No Oil War)
I've seen it in several offroad bikes and one street bike. My experience and research indicates that it is only applicable to multi-grade automotive synthetics that contain a friction reduction agent. The "damage" does not seem to be permanent if it's replaced quickly......although I suppose if left in long enough it would eventually cause a problem. Also, seems more likely to be a problem if the bike is "ridden like it's stolen". Hard acceleration. Somebody who never wraps out their bike, and basically just gently cruises......may not ever notice and may have no issues at all.I keep hearing about the fabeled wet clutch slippage.... has anyone actually had a slipping wet clutch or are we passing along an urban myth? much like the story that synthetics will make good seals leak.
I heard it about synthetics 30 years ago... about the newer oils 20 years ago... etc etc etc
I have run nearly every kind of oil in my 1000 and have never had the clutch slip
That is only part of the story.All major motor oils (motorcycle motor oils included), contain some
degree of additives designed to help reduce (primarily) viscosity breakdown,
by reducing or eliminating ......
that was a good read full of great info..thanks KLwatts.cyclewizard wrote:That is only part of the story.All major motor oils (motorcycle motor oils included), contain some
Full article can be read here > http://www.motorcycleanchor.com/motorcycle/how_to/mc_oil.html
