1 - 9 of 9 Posts
I took the bike out the other day around town for about an hour. Did 5 stops with no problem, then backing it up 40' up the hilly (10 % incline) driveway into the garage. Then turned it off to open garage door & it wudn't start again. All I can figure is reverse is electric & maybe wore the battery down, altho it says 12.15 V on the multimeter. In all fairness, the battery connections were a little loose, but obviously good enuf to drive around all summer. How can I prevent that from happening again? Just take it for a good run to charge up the battery?
Thanx
You cannot check the health of your battery with a multi-meter, it does not put a load on the battery. Most discount parts places will check a battery free of charge, regardless if it is their brand or not.
I am like AZgl1500, I think if you clean and tighten the post, put a charger on it, it will be just fine.
40' up a 10% slope is a lot to ask of the battery even with the engine running the alternator will not keep up with the demand.
a good battery tender will fix you up just right.
+1 on that specific charger whether the standard or mobile unit.
Connections should always be clean and tight too:)
One thing to watch for: If you can't seem to be able to get the terminals tight enough, look for spacers on the terminal ends missing. Some stock batteries come with 2 little spacers that go on the battery terminal ends, and they get lost. I found mine were missing, and the terminals "looked" fine, but were always loose. I also found another bike with missing spacers, and you could see where the terminals had been arcing because they were not tight. Just a thought. jimsjinx
Oh - THAT guy...
Agree- That the alternator probably just could not keep up with the load. After all, all reverse is done at idle and it is maybe/just barely charging at that rpm, let alone with the load of reverse up a hill. Charge it up and you will *probably* be fine, but next time leave it running a bit before shutting down maybe? Repeated hard drains on the battery can lead to sulfation shorts and greatly reduce battery life.
I never let the battery on one of my old cars go flat or sit more than a day and it lasted over 11 years. I bought a used car and the battery was 5 at most when it went last week (who know what the PO did the first two years he had it).
The good news, is that you can simply push the bike out of the garage, coast down the driveway and bump start the bike.
Thanx[/QUOT
I don't want to be a jerk, But did you take it out of reverse?
1 - 9 of 9 Posts
