changing oil book said 3.7 qt.has anybody put 4 qt. is that to much will it smoke alot or is it ok:?:?:?
The Honda maintainence manual specifies 3.4 qts.
even then, there is always a varible amount left behind, and so using the guage tells you when it is full
of course there was the guy I knew who thought he needed to fill his 78 wing up until he could see the oil at the fill hole.... (honest to god true story) whooooo that bike smoked!
:waving:The 1980-1983 Honda GoldWing Service Manual actually reads: Fill the crankcase with approximately 3.2 liters (3.4 U.S. quarts) of the recommended grade oil.
Start the engine and let it idle for a few minutes. Stop the engine and make sure the oil level is at the upper level mark of the oil inspection window.
When I change oil Iput in 3 quartsthen start the engine and let it idle for a fewminutes and shut it down and let it sit for 5-10 minutes. I then slowly add oil till it is at the upper level mark. Never fill beyond the upper level mark.
