the oil filter can be removed by undoing the front grille work...
my advice is to forget about that, it is a PITA to do that way.
I just remove a side panel, and use an oil filter wrench to remove it from the left side of the bike,
the oil drain plug is forward of the engine, dead center.
IF there is not a Belly Pan, no issues at all.
Get a New Crush Washer, to not reuse the old washer, way too easy to strip out the threads in the oil plug hole
and do NOT over-tighten the oil plug. Aluminum engine blocks don't tolerate that.
Some oil filters have fluted cases, this wrench adapter makes it easy to remove the filter.
Some oil filters has a Hex nut attached to the end of the case,
this wrench works well on those
Goldwing, GL1500, GL1800, Valkyrie, Oil Filter Wrench, Show Chrome, 4-201A
cyclemax.com
