hi.. bikes done 1,000 mile in 1 year since oil and filter change,been stood last few months due to winter.. am going to drop oil in next few days, i was wondering if i loosen nut on oil filter a little let oil run out will it reseal when nut is tightened up again..as filter was changed 1 year ago..ie 1000 mile...regards..jim :waving:
If I'm understanding this right, it's been a year since the last oil and filter change? Do yourself a favor and replace it all, oil and filter.
Most likely but the filters are cheap. I have reused the o-ring cause I was lazy and they have sealed. Go ahead and pull the filter houseing all the way off and be sure to line it back up carefully. It has got a locateing tab.
I would change it too. You only rode 1,000 miles in a year?
never had a problem about the oil filter seal. every filter i've bought comes with new orings, bolt and cover. always change them.
If I was going as far as taking the filter housing loose I would go ahead and change the filter too. Just my two cents worth. :)
