1 - 11 of 11 Posts
stopped into two walmart stores today and not one super tech oil filter on the shelves what brand do I turn to ? I have a 1990 1500 SE /. Thanks for any info
That's cause they stopped selling them. stay away from fram though. I have gone with baldwin for my cars now. Napa for my GL1100 and honda for the GL1000( have lots left )
mr irrelevant
wal mart sells the purolator filters , believe the # is 14612...
Answer Seeker & Kibitzer
The Purolater is every bit as good as the Supertech..
14610 or 14612 are the numbers..
I have used 3 of them this year already (every 5000 miles) and they seem fine.
http://motorcycleinfo.calsci.com/FilterXRef.html
The website says that these below fit the GL-1500 grouped as "5".... recommendations are those of that website.
These Oil Filters
have 20 x 1.5mm threads,
14 psi by-pass valve,
anti-drain back valve,
2.3" O.D. gasket
2.5" to 3.5" long.
If you have the room, I recommend the longer filters.
Motorcycle Filters.
None are recommended.
AC Delco PF2135
AMSOil SMF103
Carquest 85358
AC Delco PF2135
FRAM PH6017A
Honda 15410-MCJ-000
K&N KN-204, about $13. Metric nut on end for easy removal.
NAPA Gold 1358
Purolator ML16817. Imported, not made by Purolator.
STP SMO 17
WIX 51358
Recommended filters.
All have superior
filtering.
About 2.5 inches long
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12.Made by Champion.
Bosch 3300, about $6.Made by Champion.
Wal-Mart SuperTech ST6607Made by Champion.
About 3.25 inches long.
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10.Made by Champion.
Bosch 3323, about $6.Made By Champion.
WalMart SuperTech ST7317,about $2. Made by Champion.
Automobile Filters,
about 2.5 inches long
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
Automobile Filters,
about 3.25 inches long.
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Fram Double Guard DG7317
Fram PH7317
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Millard ML-3593
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
:waving:
Senior Guru
Interesting read. So, apparently Champion and Fram are in bed together. :needahug:
I wonder what will happen to the Champion quality?
Wix is still owned by Dana, still supply the Napa (over priced), but these days, anything can happen overnight. Can we say CHINA?, down the road for most, if not all?
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2358100
Vintage Rider
I use either Emgo or Parts Unlimited filters on all my bikes. I have always used SuperTech filters on my cars. So far Wix makes good filters, they are well known as a fleet filter, and are commonly used by professional fleet mechanics. Fram is JUNK, period. Anything made by Fram is junk. Filter brands men very little anymore, as the manufacturers keep changing. As was said, at some point, they will all be made in China. Honda is already getting some of their cheaper bikes and scooters from China.
Bosch 3323 in both the GW and the VTX....good luck on your choice...
1 - 11 of 11 Posts
