I have a 1984 1200 asppy and have an oil issue on the rear tire and gearbox.if i check the gearlube its at the correct leval. the rear tire and gearbox are coverd in oil if you go for an afternoon ride when you get back and park it there is a puddle of oil buy the back tire. if the rear engine to driveshaft seal is bad will it show up under the rear tire? if the seal is bad can i change it without removing the engine? and why is the gearcase still at the correct oil level and not overfilled? I thought it originaly was the shock but I am shure its got to be comming out of the gearcase but how?
please help me before the season starts.
