1 - 14 of 14 Posts
1987 GL1200 Interstate
First, welcome to the forum.
Second, you are going to need a new water pump real soon. Use an OEM pump, and only silicate-free coolant, or you'll be doing it again in a couple of years.
o ring or leaky washers or the seal but all three require the same tear down..drain radiator, trans cover which requires all new gasket set $22, pumps about $100. If you take the front elbow off you can see the i,peeler..if you can move it at all side to side or up and down your bears are going out and the oil seal might be damaged..if it's tight could be one of the other oil seal sources OR still the oil seal..
also needed new mechanical seal for the pump
everyday member
No matter what you are going to have to remove the cover to get to the o ring. Being that it's an 81 I would recommend going ahead and replacing the water pump and all the o rings. Like mentioned above, buy a OEM pump. After market is just setting you up for another change in a year or too. It's not a difficut procedure to do. Goldwingdocs.com has a great tutorial on how to do the change. Take your time and it will be a breeze to do.
Junior Grue
Brian.
Be sure to change the oil pump seal as that's where the oil is entering the water pump.
On that waterpump I recommend Cyclemax.com, mine was$137.00 including shipping the pump itself was $123.00, however I'm in kentucky and their in Ohio so your shipping may be more, but it should still be less than the $166.00 dealer cost and that's not includingsales tax.OEM factory replacement from honda took about eight days to from time I ordered however their site says to allow about twelve to fourteen business days.
everyday member
Give westerhonda.com a look. Received my OEM pump in three days from time of order. Ordered gasket kit from amazon.
everyday member
front cover kept leaking around drain plug so changed front cover. changed waterpump while in there. that was monday. started leaking oil out of weep hole today. heartbreaking:praying:
Hey Doc. Welcome.
You can go to the new member forum and introduce yourself if you like or, you can start a thread on your leak and see if our esteemed panel of experts and idiots canhelp guideyou on your way to a leak-free future.
Canuck, I agree with Yooper. Western Honda is the goodest.
went back in thursday checked orings,cruch washers and applied thin coat of rtv.still leaking. must have nicked seal. just ordered new seal.This bike has been a 3 year project so far.
Discussion Starter · #14 ·
My new water pump isn't here yet but you have me worried.
How bad is yours leaking? As a former brit bike owner I think I would just ignore a small leak.
Brian
1 - 14 of 14 Posts
