Long story short, 85 GL1200 engine experienced a backlash, broke the starter chain, had that replaced and after 100 miles lost oil pressure. Pulled the engine and removed the rear cover and found the pump shaft sprocket had sheared off. Unbolted the sump pump housing and it fell apart. Found the rotors on the backside of that had shattered.
Can anyone tell me how that shaft comes out? Front to back or back to front and if it requires the cases split?
Cheers
Cheers
