1 - 2 of 2 Posts
has anybody ever had a compressor lock up?
mine did and thought it was done until i took it out and saw that the prefilter had been sucked into it. took the three screws out of the case and pulled the cover off and removed filter from piston sleeve areea reinstalled and checked it and it would turn over just fine then. so i took a chance and put it back on and it now works better than it did after i made my own filter out of a 3.5hp briggs foam filter.
Haven't had that problem, matter of fact the PO took care of any compressor problems, he took the compressor off and put progressive shocks on rear and springs in front......so I guess I'll not have any lock up problems:baffled::baffled:
Glad you got yours fixed though!!:cool:
1 - 2 of 2 Posts
