Normal, don't worry about that. What do the plugs look like now?There is also a bit of oil in the air filter
I actually found a big vacuum leak in the air cut off valve. It was missing an o-ring. I replaced it and it can now idle much better and it seems all cylinders are firing somewhat evenly. One of them is a bit sluggish still, however, when I open up the throttle they all kick in. I am hoping a carb sync will fix that!Too much fuel.
That is exactly what sync does.I actually found a big vacuum leak in the air cut off valve. It was missing an o-ring. I replaced it and it can now idle much better and it seems all cylinders are firing somewhat evenly. One of them is a bit sluggish still, however, when I open up the throttle they all kick in. I am hoping a carb sync will fix that!
Good ground connection and 12.4 volts at the starter post. Think it's toasted?The starter grounds to the engine which in turn is grounded to the battery by the cable connected behind the left rear upper engine mount. Connect your meter red to the starter case and black to the battery negative terminal and push the button, it should show close to 0 volts.
I think you are right .Yep, I would say it's broke.
If its your starter in the pic its not just broke its not repairable.
Either a bearing is very bad or the starter clutch stuck and the rngine overspeeded it A LOT
I must really be going blind. I had to go back and look again to see all the damage you were talking about. 🎅Yep, I would say it's broke.
Everything is idling perfect now, however, power is totally lost on acceleration. When I let out the clutch RPMs just sink and I stall out. I can get up to like 4mph and then it'll die. Not getting enough fuel?Yep, I would say it's broke.
One other thing, the headers are glowing red... Should I readjust ignition timing?
And running too lean.Retarded ignition would be the very first place I would look. Super high exhaust temps when retarded.
