On the stripped bolt, is it just the tip of the bolt, or does the stripped part go all the way up?
If it's just the tip, then you can carefully file down the end of the bolt so that it's got a V shape, and the nut can catch some new threads as you screw it on.
Plus you should be able to go to a place like Ace hardware, or any independent hardware store and buy just the die you need, instead of a whole set.
