it's just a wafer lock, I'm sure a raking attack or a jiggler would open it.
Time to make a backup key.
1998 GL1500 Asp and 2017 GL1800 4AC
Due to situation as subject noted;
Any ideas for picking the lock?
It would be helpful to know what kind of vehicle you are talking about.
2012 GL 1800
I have never done that, but the gas cap lock on my '88 wore out, and the key wouldn't open it anymore. I ended up disassembling things until I could get at the bottom side of the lock. From there just push the latch open.
YMMV. I don't know what year you have, or whether it's similar to mine. Good luck.
That is always a good thing. I had to look back at other posts, and finally at pics (only one of which was bigger than a thumbnail) to figure out he has a 1200.
On the 1500 often the door is loose and flexible enough just to pry the door over to pop it open. But I don't know if that holds true for the 1200.
It is difficult enough to come up with a useable answer to a question but it is next to impossible to read the original poster's mind.
