[align=center]Good Morning All
I requesting any and everyones help, I need astep by step on how to place my name on the opening ceremony of my 2006 Goldwing 1800. I do not have the mode botton as one of the instructions showed.I triedusingit, and it just don't add up...at least not for me!
I'm really tring to be smarter than my equipment! lol :stumped:
I dont check this site as often asI should; but whenI doI have learned so much about the wing,O by the way this is my first Wing andI AM LOVING IT!!!!
my other e-mail address is:
[email protected]
Really need your helpI want to remove Ted's name from my wing!
Be Safe and Gods Speed!
[/align]
The Irish Crew
It's a bit different on the 2006 and later models. Push the menu button and select setup/info. Highlight Setup/ceremony and press the enter button.
Now you will see three screens. Pick one.
If you want the special one that says Hello, select that one, and under it select the special box, press enter again. The keyboard will show up so now type in whatever you want up to 17 characters. Highlight OK and click enter.
When finished highlight done and press the enter button again and it will save it for you.
Yes, you can program it. For 2006 models, select Menu on the right hand fairing control panel.....
Then select Setup/Info
Then select Setup/Ceremony
Then select Special
Then select Detail. Type what you want and select Done. The display will then show "Hello! ....... " and "See You!
:waving:
I gotta get me an 1800 if it says hi to you. Does one have to have the the nav system for this? I might borrow my brother's 1800 and program it to say hi to him. I think that might be a nice surprise for him.
No it does not have to have NAV to do that, I think the above instructions are for a NAV model. to turn on the function
Push the SETUP button to show the CLOCK ADJUST display
Push the TRIP or INFO button to switch ON/OFF.
Push the SETUP button to fix the setting.
to enter your info
Select ‘‘ON’’ on the OPENING/ENDING CEREMONY display
Push and hold the TRIP button. Push and hold the INFO button. Then push
the SETUP button.
The display should now show ‘‘STANDARD’’ in the middle line.
Use the TRIP button to select the ‘‘SPL’’ function.
The display should now show ‘‘SPECIAL!’’ in the middle line.
Push the SETUP button to select the ‘‘SET’’ function.
The display should now show ‘‘CHANGE OK?’’ in the middle line.
Push the SETUP button to select the ‘‘YES’’ function.
Use the INFO and TRIP buttons to cycle through the alphabet, number and
symbol selection.
When you have completed your message, push the SETUP button to select
the ‘‘SET’’ function which will lock in your special message to be used for
the opening and ending ceremony.
When approximately 5 seconds pass without operating a button, the display
automatically returns to the previous display.
Wish I could have copied and pasted the whole thing from the DVD but it won't let me. Had to do it a line at a time and no pictures.
