Here you go;
CUSTOM PROGRAMMING THE GL1800'S OPENING CEREMONY
(Note: For the following steps,
"Press" means 'press and release'.)
1. Turn ignition key to ON or ACC, and wait for the
normal screen display after the opening ceremony.
2. Press (press and release) the MODE button three times.
3. Simultaneously 'press and hold' the TRIP and DISP
buttons for atleast two full seconds, and then
release.
4. Press the MODE button.
5. Press the DISP button.
You should now see the word "SPECIAL!".
If not, turn OFF the ignition key, and start all over.
6. Press the TRIP button.
7. At the prompt "Change OK?", press the MODE button.
8. You should now see a 12-character line, with the cursor
at the left end. Use the TRIP button to cycle through
the available characters until you find the one you want
(letters, numbers, blank, and some others).
Note: You cannot back up when cycling through the characters!
If you pass the one you want, you'll have to cycle around to
the desired character again.
9. When the desired character appears, press the DISP button
to move the cursor to the next space to the right. The
cursor moves only to the right, and then wraps from the
right end back to the left end.
10. When the desired 12 characters have been selected, press
the MODE button to store the selected characters into memory.
Now turn the ignition key to OFF while watching the display screen.
You should see the words "SEE YOU!", with your 12-character line
just underneath. When you turn the ignition key to ON or ACC, you
should see "HELLO" and your 12 character line, and then a message
saying "Welcome to the Gold Wing World".
