Would the oxidized connections at the coils cause an intermittent spark to the plugs?
Its really weird that my motor will run on all 4 most of the time but then it gets a hair and fires on 2 the rest of the time.
I am going to pull the compartment and battery leads off today (again) and clean and solder the connections to get a positive connection on the wires to the coilstoday. Not really wanting at this point to rebuild the harness though. I figure it sat outside long enough to oxidize, It needs to be looked at anyhow - Right?
But pulling off the rear tire to get to the ignition advance ? Is this correct? I thought it would be under the points housing, Please tell me its under the points.
