1 - 20 of 41 Posts
Very nice, what are you using for paint, how you spraying?
Nice....!!!! Love the color !!!!
Pssst...you know it is the fastest....right????
Disfunctional Nimatode
Yes very good. What paint, grit sand paper and all that stuff? I have a small m'c trailer a fellow gave me and want to try something on my own as well. Am leaning towards the metal cast system that folks have been discussing and the 2 part clear coat in the can........ Candy spectra red, the lightning fast color.
It's not easy getting a gloss like that! Good job! Can't wait to see the whole thing done and assembled! jimsjinx
Great job, I take it you didn't use a rattle can.
I didn't get a finish like that even using a gun and lots of sanding on my old dodge
well done
Okay so tell us what paint you used and the steps
wilf
wilf
Discussion Starter · #20 ·
it was done with a spary can its called cherry red
its a dupli-color acrylic enamal flowed by dupli-color
acrylic enamel clear frist i sanded with 80 grit than
with 120 grit then primed it with dupli-color high build
pimer sand able then fixed anything that need to be fixed
then wet sanded with 400 grit washed it with soap and water
then sprayed the cherry red in three light coats waiting ten min.
in between coats than one good coat let it dry for almost one hour
then spryed the clear the same way let dry for 24 hours then wet
sanded with 2000 grit then buff back the shine
i tryed the metel cast panit its not as good as they say so dont waste
your money on it.
it takes time to make it trun out good so dont get in a hurry or you will
sand your but off
1 - 20 of 41 Posts
