Hi all, I have a parasitic power draw causing my no end of issues, as it can drain the battery within a few days.
My bike is a Honda 2001 gl1800.
i have done a check at the fuse box some time ago and it seemed to be main ignition circuit being affected. I did have some USB chargers that were connected to constant power on the ignition switch. I cut out these brumbies but the problem is persisting. Does anyone know of any for want of a term common problems with the 1800 ignition circuit?
Kindest regards
Rob
Suspect bad battery
Kindest regards
Rob
Hey dude, thanks for your reply, I replaced the battery about a month ago thinking jut that. No joy, but ones it was fully charged it did like to turn over better.
Rob
Did you AGM battery
someone with knowledge on how to check it will be along,only thing I could is start removing fuses till it didn’t drain,check the power every few hours to assure it was loosing voltage
Can you be more specific on which fuse?
  • Like
Reactions: redwing52
Kindest regards
Rob
If you explain how you came to that conclusion it could be helpful. Also do you have any non-OEM accessories? I usually disconnect the battery cable and using an ammeter in series with the battery post and cable end. If you find draw of more than 5 milli-amps then start puling fuses until the draw drops to normal. That is the circuit where the issue is, Here is a video that might help. The kid that made it must not have much experience but the info is good. You might already know this but I thought I might post it just in case. Hope it helps a little.
