Hi clever people.....
I have aquired a set of arm rests that are designed to fit behind the grab handles on the seat. I thought this would be a simple task, but I have a slight snag.
On my 1800 the handle has a shaped tapered rubber piece with a hollow shaft running through it for each bolt mounting. The tapered rubber fits into "cupped" shape receivers on the seat apparently. The arm rest mounting bracket has holes that neither the tube nore tapered rubber will pass through.
I am now assuming that I will have to cut off the tapered rubber and shaft fluch with the flat of the handle and insert the cut off pieces behind the armrest mounts to keep it all in line correctly.:shock:
Below is a picture of the grab handle ends with the dome shaped area shown and the next picture is of the mounting plate of the armrests.
Anyone come across this issue and can advise me what they have done, before I take to the grab handles with a hacksaw!!!:baffled:
Discussion Starter #2
Grab handle cones/ tapers/domes at the seat mounting point above and the armrest mounting plate pictured below.
I did consider this BB, but the rubber dome, would have keptthe handle pushed out and that dome shaped rubber seems to serve to retain the seat material around the holes. I did't want the seat ending up tearing over time, just to satisfy my desire to fit the arm rests.
Anyhow, this is what I have done: I cut the domes and tube off, flush with the flat surface of the handles and put them as spacers behind the bracket. That has worked satisfactorily.
My next issue was that the mounting bracket on the left side of the bike, fouled the rear heated seat control. Not wanting to do any major damage to the chrome, I got round this by bending the arm rest bracket round from 90 degrees so that it was clear of the seat controller. This took some serious beating with a hammer and a piece of wood to protect the chrome surfaces. I have not bent the other side's bracket, since it is not fouling anything and the difference is not noticeable.
So, basically, "job done" as they say. :):waving:
Couple of new shots of the bike with arm rests fitted in the gallery now. :D
I found this interesting because the armrests I have offered up as a prize in the short story competition are exactly the same.
I decided there was no way I could make it fit on the left, hence the offer!
I wondered about the domed piece but didn't want to cut my handles. In fact it isn't necessary, the bracket can go flush against the seat, and the handles stick out a bit, looks funny though.
There isn't actually a domed bit on the seat, the stuffing stops short around the hole, so the end of the cone goes down to the metal/rubber bushing and the seat material fluffs up around the dome to look good.
Seems to me the cut off dome is a good idea, but I don't know about blodging the bracket :cheeky1:
I did consider making a piece of something to go over the bracket dome outside of the mounting plate so it would look better than just the straight bracket, but the only way I could see to fix the heat control thing was to cut a hole in the bracket, then it would rust etc.
I just told the missus she couldn't have armrests.
Discussion Starter #10
You have described exactly the issue that I found and the only difference is that I chose to cross myself and just go for it!!!!:shock:
I was gutted to find that the bracket was going to foul the heated seat control but having cut off the domes and found that it worked for that problem, I was determined to then overcome the fouling issue. Despite the effort, the ammount the bracket needed bending was very little and it clears the controler by some 1/2" now.
To clarify, I got these armrests secondhand from ebay, much more cheaply than I would have had to pay for new, so it was less fraught with worry than it might have been with new ones. Having fitted them I would say that I like the net result, they are nice and sturdy and look good. The rests do not have to be swivelled outwards to enable opening of the top box lid or the cubby pockets, they can remain in the "closed position". The down side will be a more fiddly job to remove the seat, with those domed spacers to consider as well as the arm rest bracket.
Unfortunately there are no makers marks on the armrests I bought, so I cannot pass that info on I am afraid.
Anyone wishing to buy ones that mount under the grab rails would do well to ask if the ones they are buying will fit the model with the seat heater control fitted. :waving:
