I was going to install the Kuryakyn armrests with folding drink holder, but after doing some research, I came to the conclusion that they are mounted to the trunk and cannot take much weight. I would prefer the more beefy armrests that mount to the hand-holds, but then I lose the cupholder, which is also a "must-have" for my wife.
I am considering the Chrome Werks armrests, and possibly the combo kit that includes the driver backrest. However, I'm not sure that the driver backrest would have enough versatility to make it worth the money.
Does anybody else have something different that they would recommend? The driver backrest is not a requirement, as I can get a Utopia separately and know that I'll be happy with it. My main concern is getting armrests that don't bolt to, or interfere with opening the trunk, and that provide a means for attaching a drink holder.
We put on the Kury ones and they work fine. True you can't lean your full weight on them, but we haven't found that a problem. They don't interfere with anything, and IMHO they look way better than the other kind.
I use the drink holder myself when I am on my own, I switched it to the left hand side.
02 GL1800 w/Auto Pilot
My bike had the ones that bolt onto the trunk brackets.
Never had any issues at all.
I have a set of the ones that fit to the hand rail holes and you should be aware that if you have the seat heaters the brackets will need bending to miss the passenger controller.
I am not unhappy with this, especially as I snapped them up on ebay at a reasonable price.
I have simpley fitted a cheap and chearful cup holder by drilling it and mounting under the front of the armrest using the existing securing bolt for the padded bit. Works just fine.
I went with the Hondaline armrests and a beverage butler drink holder that mounts on the antenna bracket, I know the armrests are much shorter but you can open the trunk without swinging armrests out of the way, I really like the beverage butler but they cost so dam much
The ones I describe here do not need to be swung out for opening of the trunk either. :)
