Hello, First time poster here. Is there a repair kit or replacement for the door next to the passenger? The plastic hinge broke. Thanks for your help.
There is always Bikebandit.com as well, just to give you several options.
http://bikebandit.com/
hhans, mine was broke on one side when I bought my 1500 a couple of years back, fixed with a small zip tie, still there and works good. Mel
"fixed with a small zip tie, still there and works good."
Although I would have purchased a door if I knew they could be bought for $4.00 I did the same thing. Drilled a hole in both the door and base and ran a Nylon tie through both holes. Doesn't look too bad and works well?
