1 - 9 of 9 Posts
Hi there, I'm trying to avoid sewing if possible.
Is there any good glues out there?:?
Thanks!
Yea, I picked up a couple here while back. One I got from the local Ace hardware called Pliobond, it is a contact cement that worked very well.
The other I got at my local Hobby Lobby, called Tanners Bond Leathercraft Cement and it worked so well that a guy pulled on my patch and it pulled a layer of leather off with the patch. Needless to say he had to pay to get it sewed back on for messing with it......lol
I found a good heavy object like a brick works well and make sure you cover up to the edges. I also recommend that you use a knife and make cuts into the back so that you get the cloth material exposed if you have the iron on backing on a patch.
Jeff
Jeff
Isn't it awkward in the twisties carrying that brick around on your jacket?:)
fenry wrote:
Jeff
Yeah but I bet it would be good for tail gaters.......:D
Actually I prefer to have mine sewn on. Mine are just done with a single stitch for now until I get a better vest then they'll get double stitched on.
I sew mine on myself. Just takes more time if you don't want to sew it to the lining too.
James
I cut the edge of the liner loose so I can sew the patch directly onto the leather and then stitch the liner back once I am done.
Now guys, do I really have to explain the brick to you.......lol
I stopped gluing mine on after the guy ripped my jacket by pulling on the patch. The little edges don't glue down well and will curl up a tad which is what he yanked on. I learned to sew years ago and do it by hand until I can buy a machine to handle the leather.
1 - 9 of 9 Posts
