1 - 17 of 17 Posts
I have been working on my GL1100 for about two weeks now and having never owned before I have no idea what to expect as far as acceleration or top end. I ride a 99 1500 Vulcan classic and an 81 sportster that I restored from the ground up. I rebuilt an xs1100 Yamaha last year so I am not new to wrenching. I suspect carb problems but this one of my many weaknesses. Is there a video available that has a walk through? I deal better with pictures. Thanks...Cosmo
Randakkl sells a booklet to go with his carb kit for the 1100. He sells a video but it is specific to the 1000 series. For straight line performance it should be above your sporty butbelow your XS.
My performance is way short of these specs so it looks like I need to start looking into why. Any ideas before I pull carbs?
I would go with a Sea Foam treatment. Just do a search on this site, lots of info on this topic. Do this before you pull carbs etc. and then try riding it. Also drain the carb bowels. This will make a big difference in the way the bike runs.
Drag times are under ideal conditions with a professional driver so one's own results will be different. There is not a lot of difference in drag times of the 1000-1100 bikes. Somebody will take me to task on this one.
These bikes once you get the revs up in the 6500+ range will really haul ass. The earlier wings 75-77 came out in the times of the early super bikes so they like to rev. I wouldn't subject them to this type of treatment on a regular basis but save it for when you need it.
O.K. I am a believer in SeaFoam and put some in when I first got the bike and have run three tanks with it in. It ran poorly but I did not have any idea what to expect. Put new plugs in two weeks ago and pulled them today. #3 cylinder plug was black...the others looked great (light brown). Going to try the easy things first. Plug wire, then valve adjustment but have a sneaky suspicion that carb is the problem. Is there an easy way to check?
Sounds like you know what you are doing. Check the ignition, valves, and I would also do a Compression test. If nothing rears it head during those then you need to look at the carbs.
Discussion Starter · #9 ·
Update #2...Pulled the carbs, dust in the #3 bowl. Time for a good clean...Cosmo
if you're not new to wrenching you may not have any problems at all. i did my 1200 with no experience. only using service manuals. tuned to manual specifications and she runs great. use randall kit which is the best.
i just redid some 1100 carbs last week found the tubes that carry gas to different carbs were cloged cleaned them out with parts cleaner. cleaned little fillers made a world of differnce
I think the Goldwing 1100 is pretty fast. As fast as my CBs were and more.
The main thing I like is that it has enough power for driver and passenger when going up hills without shifting down all the time. A great long distance bike at 55mph+.
Discussion Starter · #13 ·
Got things back together yesterday and what a difference! The float in the offending carb was upside down. Tremendous power boost when four are working. I will run a couple of tanks of gas with Seafoam and and sync. I might even buy a speedo cable and check mileage. I am thinking about 35mpg? Is that about right?
I get a steady 40mpg on my 83 . Glad to hear you have her running better now.
Depends greatly on how fast you ride ... above 65 and the mileage will drop a lot.
Our '80s generally run 45 ish. As high as 50 mpg and as low as 35mpg (with trailer and head wind).
Performance and mileage also vary greatly whether it's a Standard or Faired GL1100. My '80 Standard had much quicker feeling acceleration than my '82 Aspy. That's an objective observation since I never had either on the clock but the Standard version is much lighter which helps with the acceleration, I don't know about the difference in top end, the Standard was a bit hard on this old guy at 100mph. I like hiding behind a fairing at higher speeds.
Ya just gotta love that skinny lookin' machine. I hated to sell that bike after rebuilding it but the profit from that paid for my Calhoun trip. Jluvs2dive had a GL1200 Standard that was beautiful, unfortunately he also had to sell it once he got it in running shape. I hope to have my '76 in roadworthy shape by this spring, these old naked 'Wings are a blast to ride. I'll never sell my '93 Aspy, but having a naked 'Wing for local rides is great.
I totally agree with Exavid. Those specs above were for a Standard model. Pretty quick for a wing. I picked up an 83 Aspy that hit a deer. I am converting it into a Standard and am looking forward to riding it.
1 - 17 of 17 Posts
