OK I just did a MAJOR overhaul on my 1500. I replaced new seals, new bushings, new progressive springs, top and bottom steering bearings and now after around 300 + miles not only do I have a low speed wobble , but it's leaking on both tubes???. I followed the not only the manual but also several different diaghrams for the seal install. It all went smooth!!. I used OEM parts for the forks, so there is no after market stuff in them. I followed the turorial on this site during and after the install??. I don't believe the seals were installed upside down. I tried to apply air pressure on the tubes today and it would hold only for a few moments. I put 10.9 OZ on the right fork and 11.0 OZon the left. The only thing I can think of is when I seated the seals into there seats I used a piece of PVC tubing and tapped it with a soft blow hammer to seat them. I may have cut the inside of the seals??. I tried to pump up the tubes today with air and squirt soap around the dust seals to see if it was leaking air!!. No leaks around there!!. So short of removing the front end again does anyone have any other testing methods I can do before the removal????.
THIS REALLY SUCKS!!!!!:needahug:. I NEED A HUG!!!!!!
99 GL 1500
Thanks Allan
Thanks Allan
