Please, disregard my post about using clear plastic for master cylinder.
691 Views 5 Replies 4 Participants Last post by  newbiker
Sorry for misleading. I will probably get piece of trash glass from HomeDepot or Loews.
I have read somewhere that it is possible to cut glass under water with scissors. I believe it as long as you cut little pieces off.
thanks for the info. you should try something like a dremel to cut and trim the glass.
I have cut almost perfect flashlight lens with scissors under water. You have to start a little large and go in left hand circles. Not bull, and even won a nice piece of glass from a glass shop when the owner bet I couldn't do it.
Thanks, Mike. I didn't cut plastic under water but cutting was OK after I realised that I have to cut small pieces.
newbiker wrote:
Sorry for misleading. I will probably get piece of trash glass from HomeDepot or Loews....
I suggest that you post this info in the thread where you made the misleading recommendation.. the way it is now, you'd have to find both threads to get it right..
"Error
Sorry, your posts can only be edited within 99 hours of the original posting."
