1 - 11 of 11 Posts
Hi all,
My 88 1500 had a flat spot and surge problem. I talked to a mechanic and he said the cap resistors could be causing the problem. He said the caps just unscrews from the wire. NOT! I broke the #2 and #4 plug wires, destroyed the boot on the #2 trying to fix it and now I can't find the cap 2 ignition wire. It's no longer avalible.I looked to see if I could use one of the other wires but #2 has to bend around a hose,the boot angles forward around the hose. Anyone out there know where I can get one or, have another idea? Thanks for any and all help! I have 2 diferent part #30752-mn5-000 30752-mt8-601
If you can't find those, you can try fleabay for a full set of coils and wires. I sold a complete set last summer for 20 bucks.
After you get the wire situation done,your flatspot is common on 88-89. There's a TSB on it. Some people use a trigger wheel to mask the flat spot hesitation. Good luck.
Thanks for the reply. I rebuilt the carbs and the flatspot is gone. Are there aftermarket wires avalible? I see there is a set of ciols and wires for a 99 1500 on ebaydoes anyone know if they would fit an88?:?
I was told by the head mechanic @ our honda dealership, that ALL models of Goldwings plug caps unscrew off.... :?:?
The part that snaps onto the sparkplug unscrews from the plastic housing inside the boot, the wire enters in the other end and there is a small washer with a hole. The wire goes through the hole,and is soldiered to the washer. So you have the spark plug cap, a spring, resistor, and the washer w/the wire soldiered to it, all inside a brown plastic housing inside the rubber boot. Unless I'm missing something,:( I don't see how the cap unscrews from the wire without breaking the wire.
Maybe we are talking about 2 different things,I was talking about the spark plug cap unscrewing.
I have never replaced any but I had asked my mechanic right before I ordered a set for my brother-n-law.
[align=right]
102 Degree Elbow Type, 10mm and 12mm Adaptable Plug Thread Size, 5ohm Resistance, For Terminal Stud, With Special Water Proof Cover
NGK - XD05FP
Automotive Fitting:
We do not have an automotive fitting for this part in our database.
Non-US Automotive Fitting:
We do not have a non-US automotive fitting for this part in our database.
Non-Automotive Fitting:
Category
Make
Motor Model
Motorcycles, Minibikes, Mopeds, Scooters
HONDA1987-1986 VT700C
700
HONDA1990-1988 GL1500 GOLD WING
1500
HONDA2001-1998 VT1100T
1100
KAWASAKI1990-1988 ZX1000-B NINJA
1000
KAWASAKI1992-1991 ZX750-J NINJA
750
KAWASAKI1992-1991 ZX750-K NINJA
750
KAWASAKI1993-1990 ZX1100-C L/C
1100
KAWASAKI1994-1993 ZX750-M NINJA
750
KAWASAKI1995-1993 ZX750-L NINJA
750
KAWASAKI1996 ZX1100-F L/C
1100
KAWASAKI1997-1994 ZX900-B NINJA
900
KAWASAKI1997-1995 ZX1100-E L/C
1100
KAWASAKI1997-1995 ZX600-F NINJA
600
KAWASAKI1997-1996 ZX750-N NINJA
750
KAWASAKI2000-1999 VN800-C VULCAN
800
KAWASAKI2003-1996 ZX750-P NINJA
750
KAWASAKI2005-1995 VN800-A VULCAN
800
KAWASAKI2005-1996 VN800-B VULCAN CLASSIC
800[/align]
Correct orientation of the screw retainer, resistor and spring
Discussion Starter · #8 ·
Mine doesn't look like that at all. Thatboot looks like it's plastic. The only thing that is plastic on mine is what holds just the cap, spring resistor and wire inside a rubber boot. I don't have a camera to send a picture. sorry. The rubber boot has a flange around it . when it snaps on the plug, the flange seals out dirt etc..Thats the best I can explain it
kyboy67 wrote:
[font=""]Correct orientation of the screw retainer, resistor and spring
those look like they will fit the 1100's but NOT the 15's
and even the 1100's dont have the resistors/and or screw retainers
mark:waving:
You can get most every part especially plug caps and boots and alot of other OEM stuff from Cheap Cycle Parts , i just ordered one a couple of weeks ago. they have the best prices also. as far as plug wires go a goldwing mechanic told me to go to the auto parts store and get a set of the old style copper plug wires for an older car and replace the old ones with the copper, you have to cut them to fit but he also said not to use the new plug wires that are not copper they do not work as well.
jones183
Discussion Starter · #11 ·
I just picked up a set of coils and plug wires off e-bay from a 99 1500. Looks real good. $10.00. The plug cap doesn't unscrew from the wire. Ifit does,you have a broken wire. Thats on my 88 1500. The coils, wires and capsI just got from the 99look the same as the 88
1 - 11 of 11 Posts
