1 - 13 of 13 Posts
I've got into the habit of plugging and unplugging my intercom cord at the junction next to the helmet. So far, no problem. However, those pins are small and delicate. I assume it was meant to be disconnected/reconnected at the heavier duty 5-pin plug on the bike end of the curly cord.
Anyone that uses the top end of the cord as the plug in point - had any trouble wearing it out, bending pins, etc?
Sure is more convenient for me to do it that way - so I must be doing it wrong.
Gregarious Greeter
My wife has broken a few of those small pins. We disconnect at the larger end.
Our JM headsets have two cables for each. The upper cable plugs into the helmet and then into the lower cable. The lower cable then plug into the large 5 pin on the bike.
I usually like to plug and unplug the connection between the upper and lower cables. I have had a problem with the small pins at that connection. I broke bent one while on a ride in Oregon. In trying to bend it back it broke so I ended up riding the balance of the trip with one speaker. Even after having to buy a new upper cable I continue to use the smaller connection due because it's easier. I am now very careful plugging them together.
WE JUST LEAVE OURS PLUGED IN ALL THE TIME JUST TAKE OUR HELMETS OFF,UNLESS WE GO IN TO SOME PLACE.THEN WE UNDO AT THE BIG END..
Goldwing Addict :-)
+1 on this. I've been doing it this way for a little over a year and 18,000 miles, since I got the 1500 and started using J&M headsets. No problemsyet. The version I have, the mid-range sets, are designed pretty robust and you would have to work pretty hard to damage them by connecting and disconneting them between the cords.
Senior Moment Member
In the 5 years we have had the wing my wife has gone through one set of the Hondaline headsets and 3 of the J&M cords. I finally broke off one of the small pins on mine last year.
After the last time my wife broke a pin off and it stayed in the helmet, I took apart the connection at the helmet and hard wired the cords to the helmet. Now we have to use the large connector as the cord is part of the helmet headsets.
I've been thinking about the bluetooth versions but I want a set that will last for more than 8 hours and the outside box is waterproof.
Henry
My better half has broken the pins on the helmet end, also. jimsjinx
i was doing the same thing for awhile with a headset. it had a volume control at that junction. one day not thinking i yanked on the cord like always. poof i pulled the connection out of the controller.
now i disconnect at the large end.
Goldwing Addict :-)
Henry
So far that's none of them, and only the J&M's will connect to the Wing's system. There are plenty of performance issues with the very expensive J&M sets though. It's going to be wired headsets for me for awhile still.
FYI, Air Rider has been working on a Bluetooth headset for quite some time, said they would be released last year, but they still are not released. Obviously they are having some real issues too.
Discussion Starter · #11 ·
I'm hoping someone will build a bluetooth that will just plug right into the built in J&M headset plug on the side of my Arai. Then maybe I will switch. But if you cut the intercom cord, you have the battery life and recharging cords to deal with.
So far, my upper connection is holding up to the disconnects, althought I know I should probably use the lower one, its a pain having the long cord hanging off the helmet.
Goldwing Addict :-)
Yeah, but you would also need a bluetooth module on the bike's end too. Gotta have something to communicate with. :)
Discussion Starter · #13 ·
Yes, but hopefully they would sell it as a package.
1 - 13 of 13 Posts
