What spare parts do you have for your GW?
  • None
    Votes: 0 0.0%
  • Alternator
    Votes: 0 0.0%
  • Starter
    Votes: 0 0.0%
  • Fuel Pump
    Votes: 0 0.0%
  • Carb
    Votes: 0 0.0%
  • ECM
    Votes: 0 0.0%
  • Radio, CB, Instrument Panel or Display
    Votes: 0 0.0%
  • Rotors
    Votes: 0 0.0%
  • Headlight
    Votes: 0 0.0%
  • ABS Plastic Covers
    Votes: 0 0.0%
1 - 20 of 24 Posts
I am wondering if ya'll are like me and acquire spare parts for your GW(s).
I listed several expensive parts above. Due to the high cost, Iacquired many through e-bay and shelf them knowing that Murphy will be around someday.
I have half on the listabove except the alternator, LCM display,CB, radio,headlight, and no plastic covers. I bought three covers, but they were after Murphy came and were immediate replacements that hurt me $ pretty bad.
I was limited to 10 items. My 11th would have been a "parts bike".
Poll will run 10 days.
I have crank triggers honda calls them pulse generators. I do not carry parts when ridding, would rent Uhaul bring bike home if had serious problems.
I carry spare plug's and a tire kit and other odd's and sod's on the bike . I also have spare internal's from an engine and half a engine casing .
I was thinking engine parts, carry a tire kit,fuses,duct tape,black tape,headlamp bulb,roll 14 ga. wire, tie wraps, tire gage and multimeter.
Lost on this *****
I have (but don't carry them) brake pads with a good 50% left on them. Also have a windshield that was on the bike when I got it.
It would be nice to have other items at hand, like alternator and such.
I now havs an alternator I carry a fuel filter, fuel valve, various light bulbs, wire connectors, air line and fittings for trailer, patch and plug kit, spare tire ans tube for trailer, and fuses.
I heard about alternators failing, so I carried a spare with me when I traveled up to New York this past summer. But other than that I don't carry it. It's just in the garage for when mine eventually fails.
I have a spare front wheel and two spare rear wheels. (the second spare rear wheel wasn't intentional, but it came cheap so I couldn't pass it up.) Having the spare wheels is convenient when it comes time to change tires. Since I take the bike apart in my garage to do it, then take the wheel down to the dealer and have them put the tire on it, I don't have to worry about if they are busy or not now, I can just drop it off and pick it up later and then have it ready in the garage when I am ready to do it. I have extra rotorson each of the wheels. But right now that's it.
Oh yeah, I have an extra set of carbs, but they aren't functional. One of the pilot screws is jammed in and I wouldn't try using the carbs like that. But they made for good practice before I overhauled my carbs....
Tire plug kit, 12 volt compressor, Honda tool kit, bottle of water, sharp knife, 15 foot ratchet tie down strap..
If you ever have a flat and loose the bead, without the strap you'll never get the bead to set.. That's from experience..
Why we need spare parts? These things last FOREVER!:D
On trips,throttle cables, brake pads, fuel filter, clutch cable, oil filter, oil, plugs, tools, meter, flat fix, spare fuel lines, fuses...
A spare goldwing in the left fairing pocket
Probationary
Iron Butt states this as minimum for long distance.
In my leather Travelcade tool bag, 4 X 5 1/2 X 11 inches:
10 in. Channelock pliers
6 in. Channelock pliers
6 in. needle nose pliers
5 in. flush cutting wire cutters
5 in. wire strippers
6 in. locking surgical forceps
4 in. 1/8 flat blade screwdriver
4 1/2 3/16 flat blade screwdriver
4 in. 00 Phillips screwdriver
6 in. #1 Phillips screwdriver
7 1/2 in. #2 Phillips screwdriver
7 1/2 in. 1/4 in. flat screwdriver
Xcelite four way driver
Magnet, general use, small
6 in. Crescent Wrench
Short 1/2 - 9/16 in. open end wrench
M 10 X M 11 open end wrench
M 12 X M 14 open end wrench
M 10 X M 11 box end wrench
M 12 X M 14 box end wrench
M 17 X M 19 box end wrench
MAC combination six point Flex Box End/Open End, M 10, M 12, M 14, M 17 wrenches
4 oz. ball pien hammer, with handle shortened to 7 in.
M 5 hex key - short arm
M 6 hex key - short arm
M 5 Ball end hex key - "T" handle - 8 in.
Machinist's scribe, self storing point
6 Straight edge razor blades
6 C.C. tube of Locktite
6 Oz. tube of RTV clear silicone sealer
Two Tube 5 Minute Epoxy
Zip-lock bag of Anti-Seize Compound
Zip-lock bag of rear spline lube, Honda 60% moly paste (for rear tire change)
The two above items stored in 35 MM film containers, clean, dry, protected!
Top quality padlock - with keys
2 spare electric vest wire connectors - wired
12 feet of two conductor electric wire
35-40 small zip ties - 3 1/2 in.
12 medium zip ties - 8 in.
8 in. Tire Iron
6 electricians tapes, roll ends only, very easy to carry/use
12 Pre-Packaged alcohol wipes, for general clean-up
6 Pre-packaged "Handy-Towels" for your hands, etc.
clean up towels, terrycloth
ALL - Snap-On, Craftsman, Mac, Xelite, etc., PROFESSIONAL TOOLS!
Not In The Above Kit:
Stock Honda Tool-kit
siphon hose, 5 /16 in. I.D., 6 feet long
1/4 in. Nylon rope, 15 feet long
12 in. Crescent Wrench
M 5, M 6 long arm, ball end hex drivers
Spare fuses for "EVERYTHING"
Re-chargable, 2-D Cell flashlight
AA cell Maglight, on neck lanyard, for walking bonuses/back-up
Two AAA cell Maglights
Eye glass repair kit
Sewing kit
Safety pins
Lensatic, Engineer Compass
2 Magnifying glasses, 2X, and 5X
Small mirror
Swiss Army Knife
Wavetek, DM78A Digital Multimeter
Digital tire gauge
Spare keys for "everything"
6 new Micro-Point ball point pens
MANY spare batteries for flashlights, clock/timers, shaver, Screaming-Meanies!
Buck TITANIUM locking blade knife, 3 3/4 in. blade
Spare headlight, driving light, license plate, and other bulbs
Spare throttle cables
Always kepps these in the bike as a minimum.
Then thereis a cell phone, camera [both with chargers +SD] credit card, cash, 9mm, first aid kit, etc.
No wounder they call it an Iron Butt..
Seating on all that that should call it Hemroid butt..
Probationary
OOOOHHH, You mean in the garage. I got air, Seafoam& oil.
Gettin' time to do all the filters, though.
I carry....nothing.
It doesn't matter what you carry, you still won't have the part that breaks. Tony's law. lol. Cell phone and credit card here also.
I keep an HD tool pouch kuz my friends are always in need :cheeky1::cheeky1:
For me just a spare head light, couple of bungee cords & 9mm ;)
1 - 20 of 24 Posts
