the daughter's '05 Pontiac Vibe has the yellow lenses that are crazed up bad, see them a lot around here.
Looked at cleaning them up manually, ugh!
thought I would see how much they cost?
http://www.jcwhitney.com/replacement-headlight/p3038529.jcwx?filterid=d1857y2005g2j1
$252.19 per set of 2
ugh! again
what to do, what to do....
Google found a lot of DIY links, and as bad as ours are, it appears that Wet or Dry sandpaper in varying grades is the only fix.
1000/1500/2000/2500/3000
and then you start the flannel cloth and toothpaste style remedies...
all of that is too much manual labor for me.
A good rubbing compound works pretty well. There is a buffing pad you use in a power drill that makes it easier.
