Have seen a lot about this and have been having some charging issues. Thinking about replacing the stator this winter, but what is the alternator mod and where can I find more info. Thanks
Chuck
Chuck
I think this is the Poorboy home page, its a start any way, if you enter "Poorboy mod" in the search box at the top of tf he forum page you will get quite a few references to it.
Will go that path myself if (when?) my stator gives out.
http://home.comcast.net/~rkekeis/Alternator/alternator.htm
Thanks Dan! Checked it out and doesn't seem to be to difficult, jujst want to do a few more checks to make sure it is the stator, then get a hold of one of the kits. Have to wait for winter though, got a truck that I am doing work on while the weather is still nice! :gunhead:
Guru
Eh Jakeblues, Have you fixed the 3 yellow wires that run to the left of your battery & join into a plug? They burn inside the plug & cause charging failure. You cut the plug right out & re solder the wires together. Cover with shrink tube.
